11-22-2014 04:29 PM
Hi everyone,
I'm a new user on myRIO and I tried to use myRIO to output analog signal and build a scope to measurement the analog input from myRIO.
I;m using FPGA to do this but something seems not correct. I cannot detect the excet signal from the analog output with an Oscope, the output wave seemed really wired. I hope someone can help me.
And also the sample scope I build also have some problems.
I insert my codes down below and hope someone can help me check.
Thank you very much.
11-24-2014 09:33 AM
about the codes I insert, my question is
1. for output a signal, why the graph shown on the Oscope is different from the waveform graph because even the period and frequency are different >:
2.how to trigger the signal input from the analog input pin of myRIO and show it on the screen because in my VI, when I click trigger, there is no graph output on the screen and when I didn't trigger it, it has the normal input signal graph.
Hope someone can help me, even just give some ideas.................................
11-26-2014 04:25 AM - edited 11-26-2014 04:25 AM
Hi constantinex,
Has your code on the FPGA successfully compiled and is there any data being passed out?
Try sending a simple sine wave from the FPGA over to the RT Host.
You can find plenty of examples on the following link:
https://decibel.ni.com/content/community/academic/products_and_projects/myrio?view=documents
I hope this helps,
06-23-2020 03:26 PM
Did you find any solution for this issue? I am experiencing the same problem nothing seems to be working so far.
07-29-2020 03:07 AM
I have exactly the same problem. If you find any solution for this issue please share the idea with me. Thanks.
