usb 6008 i/o programmable as input or output
Hello
Of USB 6008  Digital I/O , I read ( in it's user manual ) that: " Each channel individually
programmable as input or output" .
I find it possible to configure that in Max , But after Power-On all channels turn to input, and I have to configure them again.
Dose somebody know if it is possible to program that I/Os to outputs in LabView , without using Max ?
___________________
Try to take over the world!
(7,400 Views)
Hi tst-
Absolutely!  The settings in MAX are only for testing purposes and do not persist when you close MAX.  For examples of how to read and write to the digital lines in LabVIEW, check out the examples (Help>>Find Examples) called "Write Dig Chan.vi" (Hardware Input and Output>>DAQmx>>Digital Generation) and "Read Dig Chan.vi" (Hardware Input and Output>>DAQmx>>Digital Measurements).
You can configure individual lines for input or output by entering "Dev1/port0/line0, Dev1/port0/line3" and so on for a non-contiguous list of lines or "Dev1/port0/line0:3" for a contiguous list from 0 to 3.
Hopefully this helps-
Tom W
(7,384 Views)
Hello Tom
Thanks !
tst
___________________
(7,372 Views)
