10-09-2020 04:38 AM
Hey everyone,
I have a fairly simple process to devellop, or so it seems. I need to acquire an analog signal compose of a baseline and non periodic peak event. and I need to be able to detect and count those peaks and also generate a TTL gate for each to trigger another device. it's a relativly slow signal so 100ks/s is enough
two additional constraint : Labview is neither my strong suit nor used in my lab, we would like to use python.
do you think I can use the myDaq hardware for this application?
also, I'm using a laptop, I need an usb connection.
Many thanks in advance
10-13-2020 01:32 AM
Definitely you can, you might be using below driver.
