servo motor
how to move the servo motor continuously in one direction using LabVIEW and NI Elvis
Message 1 of 17
(10,536 Views)
Hardware: If your motor consumes current that is small enough to drive by ELVIS DIO, you can connect motor to ELVIS DIO and drive directly, but if it's not, build a drive circuit on ELVIS to dirve a motor.
Software: Just simply control a DIO to drive a motor/circuit. You can vary the speed by changing its duty cycle.
Message 2 of 17
(10,532 Views)
how to make a program to control a motor?
how to build a drive circuit on ELVIS to dirve a motor.
Message 3 of 17
(10,273 Views)
- Help>>Find Examples>>Hardware Input and Output>>DAQmx>>Generate Digital Pulses>>Gen Dig Pulse Train-Continuous.vi
how to build a drive circuit on ELVIS to dirve a motor?
- http://www.educypedia.be/electronics/circuitsmotorcontrol.htm
Message 4 of 17
(10,266 Views)
i need help how to run the graph continuously. here, i attach the program what i've done. i actually try using loop to make it move continuously, but i can't make it. i hope you can help me. thx...
Message 5 of 17
(10,114 Views)
Can you attached what you're trying to read?
Message 6 of 17
(10,105 Views)
Message 7 of 17
(10,105 Views)
im sory for my message before. its not include with my data. right now, i just done about take emg data and implment in labview. i've already done by doing like in attachmen i give. now, i need help how to run the graph continuously. here, i attach the program what i've done. i actually try using loop to make it move continuously, but i can't make it. i hope you can help me. thx...
in my attachment, i cant attach the last one data because there only three atachment can attach here. in my attachment, i already convert the type of format from lvm to txt because The file does not have a valid extension for an attachment.
Message 8 of 17
(10,103 Views)
this the complete data that i was forget to attach.. hope you can help me...thx.
Message 9 of 17
(10,083 Views)
1. Configure how many samples you wish to acquire each iteration in segment size
2. Put while loop around your code
Message 10 of 17
(10,069 Views)
