rotary inverted pendulum setup
I'm working on my senior design project (computer engineering) and need help getting started with LabVIEW. I decided to the NI ELVIS/Quanser Rotary Inverted Pendulum which we have in the school’s Control Lab. I've done some research on control systems and I would like to design a PID controller. The problem is that I am completely new to LabVIEW. I am searching for user manuals, VIs, and any documentation that might help me to setup and run the device. I was told it came with the documentation and VIs (which have been lost) necessary to balance the inverted pendulum so I plan to study the predesigned program (if I can find it) to learn how it works and then modify the system to design a controller for a double inverted pendulum. Anyone know where I can find the documentation I need to get started with setting up the hardware and running the program to balance the pendulum? Any help would be much appreciated. Thanks.
(7,608 Views)
There is an example VI that is included in the software.  It may be worth checking the computers in the lab to ensure it was not previously installed.  Below are a few links that may help you get started- hopefully this helps!
Elvis User Manual
h_baker
(7,586 Views)
