roboRIO configuration Error
I was working on the roboRIO these days. And I try to get the image from the
USB camera from the roboRIO I got.
I was following the instruction on imaging your roboRIO. However, I found the
safety LED turned on after I finishing format. Then I found that it says the
Labview version I installed (Labview 2016) does not match with the roboRIO (the
packet I chose for reform is FRC_roboRIO_2018_v17.zip.).
So I followed the instruction of "Launch the getting started wizard" and it
starts to install the software to roboRIO. However, the installation always
failed and I don't know what to do and what happened. (the safely LED is off
but the status LED is blinking 3 times every a few seconds. I believe it is in
safe mode according to the user manual).
The message below is the error I received.
Error -2147220312 occurred at nisyscfg.lvlib:Install Set.vi:1500001
Possible reason(s):
NI System Configuration: The execution of an external command, script, or
application failed.
Complete call chain:
     Target_InstallSW.vi
     UpdateTargetPage.vi
     UpdateTargetPage.vi.ACBRProxyCaller.8F10003B
Can somebody help me out?
Message 1 of 1
(2,537 Views)
