03-06-2019 01:17 PM
Does somebody have any experience by powering the myRio over 16V?
I have the issue that my battery package has a maximum charged voltage of 16.8V and I dont want to use an additional DC converter.
03-08-2019 03:15 AM
Hello @MutuThambi!
Although I do not have any experience in putting higher voltage to MyRIO, basing on specification the max voltage is 16VDC. It is not mentioned as absolute maximum electrilac characteristic, so there is small chance that it will not destroy your device, howevere I would strongly reccomend not to do so. In case of too high Power supply, basically everything can go wrong or behave in wierd, unexpected way.
Did you consider adding some Zener diode or stabilizer in place of DC/DC converter? It is really easy to use and it may save you much time,money and efford.
03-08-2019 04:21 AM - edited 03-08-2019 04:22 AM
