03-11-2016 10:44 PM
hello, i want to make my system standalone (means dont need pc to work ) using myrio 1900 board.so is it necessary to use FPGA of myrio or it can work with RT level programming?
Solved! Go to Solution.
03-13-2016 04:06 PM
Usage of the FPGA only depends on your application.
If your application does not require FPGA development, you can have only RT part, and create a stand-alone system. To create a stand alone application, you need to build RT application for your RT part of the software, make it to run as a startup, and deploy on your hardware.
Of course your RT code should not have any dependencies on Host part, i.e. network streams, Network shared variables, etc. Or at least you should handle the errors, connected with the lost communication.
Arev
CTO | RAFA Solutions
12-22-2020 04:31 AM
how can we make system standalone with Fpga Target? Is it necessary to use RT module for standalone purpose?
