02-26-2016 07:03 AM
02-26-2016 09:42 AM
Take a look at the followings links to help you find out if your camera is supported or not - and things to look for when choosing a camera:
https://decibel.ni.com/content/docs/DOC-30345
http://digital.ni.com/public.nsf/allkb/4331B4AA3AE95233862574C200539A2F
List of tested cameras: https://decibel.ni.com/content/docs/DOC-30455
02-26-2016 09:51 AM
means for compatibility my camera must be UVC protocol supported that i can conclude from all links.anything else? am i right?
02-26-2016 10:20 AM
UVC Support pretty much sums it up, yes.
05-02-2018 01:23 AM
I have a UVC compatible camera, and is tested ok under PC (U2 port) with NI MAX:
Once confirmed it is supported to NI Vision Acquisition Software, I moved the same camera to myRIO U2 port, but the image is incorrect:
What might be the possible reason to that? I found there's difference in "Pixel Format", but they are not adjustable for both sides... is it possible to set the pixel format under LabVIEW or through some file (ini?) in myRIO?
(The goal is to use this camera under LabVIEW with myRIO.)
