how to burn code on dsp kits(c6416)
i have difficulty burning vi's(code) to c6416 dsk. i have already simulated with out any errors my QAM modulator. it does not show any errors in simulation. but when i try to burn it on the DSK. it shows errors like "wire type not compatible with the execution target etc.
kindly guide
regards
(6,142 Views)
It sounds like you are using an unsupported data type.  Do you have any warnings or errors in the LabVIEW DSP Module Status Monitor?  That might give you more specific information about the problems that you are running into.  What version of LabVIEW are you using for this application?  Can you post a screen shot of the error that you are getting when you try to deploy your code?
Nick Keel
Applications Engineering
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
(6,123 Views)
