03-07-2019 10:41 PM - edited 03-07-2019 10:41 PM
Здравствуйте, подскажите, где можно найти примеры программ управления простыми работами на конструкторе tetrix с контроллером myrio? А как создать эти коды в LabVIEW?
03-11-2019 10:56 AM
I did my best to translate your question using Google Translate and I apologize if something was lost in that translation. If you don't mind posting your question in English, we can help better assist you on these forums.
You can also try contacting NI Support in Russia:
ni.russia@ni.com |
7 495 783 6851 |
I read up on Pitsco's website and found that there are several code examples in the “TETRIX_LV_myRIO_ToolKit” file that you get from the following link:
https://www.pitsco.com/TETRIX-myRIO-Control-Board-Adapter
Pitsco also gives more information on how to start using their device with LabVIEW in the programming guide below:
https://asset.pitsco.com/sharedimages/resources/tetrix-myrio_programmingguide.pdf
Best,
Ben
03-13-2019 10:25 AM
Hello, I'm sorry. Prompt, where I can find sample programs to control robots on designer tetrix controller myrio? And how to create these codes in LabVIEW?
03-14-2019 03:44 PM
Did you check the links I provided in the previous comment?
TETRIX® myRIO Programming Tools for LabVIEW™
"Download and unzip the file “TETRIX_LV_myRIO_ToolKit” to a folder on your computer. Open the folder and find the VI
Package installer. There will be a version number at the end of the file name; however, the version number can change as
new releases become available. Also included in the .zip file is a LabVIEW project with several code examples demonstrating how to use the VI tools using LabVIEW and myRIO to control TETRIX DC motors and servos. If you are new to LabVIEW and myRIO programming, it is recommended that you start with these examples."
Best,
Ben
