08-08-2019 08:25 PM
I've inherited a cDaq module, myRIO device, and a bunch of other serial communication devices which are all connected to my desktop. Currently working on a VI that will use all of the devices.
Is it possible to use the Analog I/O from the MyRIO in a regular VI that's going to run from the computer (not the MyRIO FPGA)? I'm running into a bunch of issues when I try to do this. Any examples that show this would be greatly appreciated.
Thank you!
08-10-2019 06:44 PM
Hello usb6009forever,
The myRIO can run code in the FPGA and its Real-Time processor. Moreover, you can connect to a Host and transfer information through the network. All the IO need t go through the FPGA, since it is physically connected to it.
If the code runs in the myRIO's Real-Time processor, one of the myRIO personalities (Choosing FPGA Personalities (myRIO Toolkit)) should work for you to avoid having to program the FPGA. Else, I recommend checking out other communication options to send data to and from your host PC: Understanding Communication Options Between the Windows HMI, RT Processor, and FPGA, and Data Communication Methods in LabVIEW.
I also recommend checking the LabVIEW RIO Developers Guide.
