09-12-2019 10:20 AM
Since the myRIO does not have a battery to maintain the system time, does anyone have code or a method to synchronize the clock on the myRIO via NTP or SNTP? I do not need subsecond resolution so accuracy within a second is perfectly adequate.
09-12-2019 11:58 PM
Hello Mark, is this document helpful for you?
Installing and Configuring NTP on NI Linux Real-Time Devices
