09-28-2016 11:42 PM
I have a myRIO (board only) and I need to read type K thermocouple measurements for an internal PID. Am I able to do this directly into the board? Or will I need an adapter?
Please be as specific as possible.
Thank you.
Solved! Go to Solution.
09-29-2016 01:27 PM
You will need a way to connect to the MXP connectors on the myRIO.
The following MXP Breadboard is an example.
http://store.digilentinc.com/breadboard-expansion-with-mxp-connectors-for-ni-myrio/
09-29-2016 08:38 PM
Thanks for the reply!
Is there a wiring diagram for doing this? I am not an electrical engineer, so please bear with me.
09-30-2016 09:52 AM
The MXP connectors just plug in to each other. You just need the female version of the connector.
09-30-2016 10:02 AM
So am I able to plug this directly to the myRIO board? I have the board only.
And is there a wiring diagram for the thermocouples? I assume each row in the MXP is represented by a pin that connects to the board, so is there a particular order I need to attach the thermocouples? Or can I just specify in the LabView which row corresponds to the + or - of each thermocouple?
Thank you for your help and patience!
10-03-2016 10:44 AM
The above listed connector is the connector for the myRIO board only.
Aditionally, the k type thermocouple has a + and - connection. So the + needs to go to one of the analog inputs and the - needs to go to AGND, analog ground. See page 5 of the below myRIO 1950 manual for the connector pinout.
10-03-2016 10:52 AM
Thank you!
This is exactly what I'm looking for!
10-06-2020 09:22 PM
The link not working anymore
