Problem in LCD 16x2 I2C with MyRIO
Please anyone can help for program lcd i2c 16x2 using myrio because the demo on youtube i2c is different LCD, mine can't display with i2c myrio VI
(80 Views)
In order to provide help for your LCD (which is different from the one used on YouTube), you should probably tell us what LCD model you want to use, and provide links to information on your chip.  Or you could just purchase the same LCD as the one you found on the YouTube video ...
(29 Views)
Hello sir, for the reason I can't buy the same one as in the video because it costs too much, I use a 16x2 i2c lcd with the following specifications:
Features for 1602 LCD:
LCD display module with green blacklight.
Wide viewing angle and high contrast.
Built-in industry standard HD44780 equivalent LCD controller.
Commonly used in: copiers, fax machines, laser printers, industrial test equipment, networking equipment such as routers and
storage devices.
LCM type: Characters.
Can display 2-lines X 16-characters.
Voltage: 5V DC.
Features for 1602 LCD: LCD display module with blue blacklight. Wide viewing angle and high contrast. Built-in industry standard HD44780 equivalent LCD controller. Commonly used in: copiers, fax machines, laser printers, industrial test equipment, networking equipment such as routers and storage devices. LCM type: Characters. Can display 2-lines X 16-characters. Voltage: 5V DC.Features for 1602 LCD: LCD display module with blue blacklight. Wide viewing angle and high contrast. Built-in industry standard HD44780 equivalent LCD controller. Commonly used in: copiers, fax machines, laser printers, industrial test equipment, networking equipment such as routers and storage devices. LCM type: Characters. Can display 2-lines X 16-characters. Voltage: 5V DC. Tutorial I WatchTutorial I Watch
(19 Views)
