07-17-2012 04:50 AM
I AM IN labeled. Could anyone help me to control micropump with labview by using ELVIS II+ ?
07-20-2012 07:46 AM
Hi SEDAT,
I am not sure what you mean by "I AM IN labeled." How ever with regards to the control of a micropump do you have a more specific question about the exact problem that you are facing with this control application?
Details of set up that you have have already attempted to implement and the associated pump details/ datasheet would be useful too.
Kind regards,
07-24-2012 05:14 PM
It was just a miswriting, I am sorry. I am trying to control two or three micro pumps (ThinXXS piezo-actuated
micropumps) and valve (pinch-valve from Bio-Chem Valve & Omnifit Compan) with labview. I was trying to test to micropumps with Elvis II+ but
now I have to use a K8055 USB experiment interface board. Simply I will pump in solution with one or two pump and then pump out.
I hope this information helps you to help me.
Thanks in advance. for your help.
