MPU-9250 myRIO
Hi, thank you for sharing.
I am trying to use your program.
The program is working,
however, I couldn't get  accel, gyro and compass data using your program.
I am connecting as follows,
A channel
VDD:33
SCL/SCLK:21
SDA/SDI:23
AD0/SDO:25
GND:30
B channel
VDDIO:33
CS:13
is it correct?
or do i have to change some number or data in program?
Naoki
Message 21 of 31
(5,330 Views)
please look at the attached image about soldering a jumper for SPI communication
Message 22 of 31
(5,321 Views)
Dear kumarasova,
Thank you for your reply.
I am using difference shape MPU9250 attached as follows,
Do you think that this element and attached your elements will operate the same behavior ?
Xaviar
Message 23 of 31
(5,312 Views)
Dear kumarasova
I was able to check the operation.
Thank you for your help.
Message 24 of 31
(5,306 Views)
What is the Y-axis unit of Geomagnetism? uT or db?
Message 25 of 31
(5,037 Views)
Dear everyone
Thank you for sharing MPU9250's VI.
I would like to know if this VI could use for port A.
Although I have already changed some stuff from port B to A such as Digital Output of Intialize_loop, the VI has not been working. What else do I have to change?
Thank you.
Message 26 of 31
(4,607 Views)
Xaviar,
some pictures will be useful to help you with troubleshooting.
Message 27 of 31
(4,596 Views)
Dear Mr/Ms
Thank you for your comment.
My project and some VI are attached on this page.
If you find some problems or mistakes, please let me know.
Thank you.
Message 28 of 31
(4,582 Views)
I am a new learner for NI boards and trying to interface MPU-9250 with myrio for my project. I connected the pins as described in the previous messages but still didn't get the data. The snapshot of receiving data is attached, which is nothing. Anyone helps me out in this.
Message 29 of 31
(3,662 Views)
The product I use is MPU-9250. I managed to run the code shared here but strangely myrio shuts down after running this code for a few seconds. What is the cause of this problem? does anyone knows ?
Message 30 of 31
(3,474 Views)
