10-13-2020 05:20 PM
Is there any way to find out what the "products already installed" are?
I have installed LV2018SP1+myRIO on a W10 Thinkpad with no problems, but with a W10 Samsung laptop (NP400B5C) with much the same software it won't install with the above error. The FPGA installs and works perfectly fine, but without the RTM none of the functions show for non-FPGA code.
The Samsung was recently upgraded from W7 to W10 and all the LV2018SP1+myRIO worked perfectly fine on W7.
Does anyone have any ideas?
Many thanks
Andy
10-14-2020 03:33 PM
To add, it works happily with LV2019SP1.
10-15-2020 09:54 AM
Hi Andy,
Simple things to try:
10-22-2020 10:47 AM
the problem is that it won't install the Real Time module because something is compatible.
It is 32bit LabVIEW and the FPGA installs fine. I've been through this a few times. Everything installs apart from the RTM.
Andy
