06-12-2018 09:01 AM - edited 06-12-2018 09:03 AM
Hey Everyone
Hardware: myRIO-1900
Software: Labview 2017
I'm not sure if this is a bug or has a purpose.
There are Boolean values and Integer values that pass through Feedback nodes, which make the values lag for the specific amount of clock cycles that you choose. In this case, I send a Booean value through a feedback node that appears on the other side one clock cycle later. Same thing should happen to the integer value, but it DOES NOT get delayed by one clock cycle.
Did I miss something here?
The VI is rather large, so im not sure if it would help.
Cheers
Buncha
06-12-2018 10:58 AM
We don't debug truncated images. Please attach the actual VI. and tell us exactly how to reproduce the alleged error using simulated data. Your code parts are quite different, for example of of the feedback nodes is inside the case structure, so it probably will not execute the same number of times as the other ones.
