I am using a PXI-6123 data acquisition card, as the picture show in the attachment ,I want to acquire the analog signal of ai0 through reference analog window and at the same time send a TTL signal to trigger my camera. I have tried two methods, one is using the DAQmx Export signal.vi another is using DAQmx connect terminals, but when the data acquisition card acquire the analog signal, the DAQmx Export signal.vi and the DAQmx connect terminals sometime can send an TTL pulse ,sometime can not.
I don’t know why? or some other method that can achieve my arm is appreciated.
Regards
chunlei
