Error testing the onboard devices. (myRIO-1900)
Hey guys,
I´m getting started with the myRIO-1900 and when I launch the "Getting Started Wizard" it´s telling me that the myRIO is found and in the next step it tells me that I have to rename the myRIO to reboot it. Then it says that an error occurred attempting to read from the myRIO´s onboard devices.
So here´s the Screenshot of it:
When I skip this I can open a new project but if im trying to run it, there´s is happening nothing. The myRIO does not respond.
When I cancel this, another window is opened but it don´t know what to do with it.
So please help to get the myRIO running.
(5,899 Views)
What do you see in MAX under remote devices?
(5,861 Views)
Hi FeFa,
please create an MAX report from your system and the myRIO, so I can take a look into both and look for any driver compatibility issues. In the following link you see how to create a MAX report:
Using MAX Technical Report to Document Measurement & Automation Explorer (MAX) Configuration Information - National Instruments
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(5,849 Views)
Hi there, i am facing the same problem here. My myRio have error while doing the onboard test. The attached file is the things i do following the step given in the website. Thanks !
(3,150 Views)
Can anyone one help me please ? i stuck at here for a long time already 😞
(3,129 Views)
