09-11-2008 05:12 AM
I am using PXI-6115s to drive and sense with piezos. I have a Labview VI for this which uses Traditional NIDAQ. When I run it I get the following error message,
Error -10401 occurred at AI Group Config -
|NI-DAQ LV: The specified device is not a National Instruments product, the driver does not support the device.......
I have ver 4.5 of the NI measurement and explorer and I am able to run panel self-test. I have also been able to successfully run the hardware with NIDAQmx and Matlab. Although, when I use the traditional NIDAQ driver in MATLAB the system hangs very often. Thanks in advance for your help!
Muhammad Haroon
09-11-2008 08:54 AM
Since it is working with DAQmx, why don't you just write the program with those functions instead of the obsolete traditional DAQ?
I suspect that the only reason you are getting the error is that MAX is setup to use the DAQmx driver. In order to switch drivers, see this.
09-11-2008 10:05 AM
