01-28-2016 11:28 AM
Hi there!
I am facing the following problems with my SBrio-9642-
1. I am unable to program it to move on a desired path. Do I need to modify the VI which is present in the rio memory? What changes do I need to make?
2. I have to interface a fire sensor with it. How can I do that?
01-30-2016 11:29 PM
Shubh77,
1. What do you mean about programming to move on a desired path? Can you show us what you have done so far and what problems are running into?
2. Can you show us the specs of the particular sensor you have?
