Applying a filter on a temperature control
I am using the pre-designed temperature control in LabVIEW NXG 3.0.2 with a myDAQ. I am getting a lot of noise from my components and want to apply a low pass filter to it to help reduce the noise. I am unsure of where to apply the filter however.
Attached is a picture of the diagram the pre-designed system came up with. Any help is appreciated!
Thanks!
(2,378 Views)
Hi samwsu19,
You would want to apply the filter function directly after the DAQmx Read VI. I've attached a screenshot with the location it should be placed in your code.
-sarahmo
(2,345 Views)
