03-30-2020 01:05 PM
Long story short, I want to use a MyRio to measure my inclination with the accelerometer.
But I would like to know what the accuracy of the angle I find is.
I have no clue if it's +/- 1 degree og if it's +/- 10...
Can someone help me solve this?
Also I hope that I have posted this to the correct board.
Best regards
Marcus
07-11-2020 11:35 AM
What a great project for an Engineer!
First, calibrate your Accelerometer. [It is surprising, and shocking to me, to work with some BME students in their senior year, and even some students in the MS Program, who wanted to measure "muscle twitch" movement with an inexpensive triaxial accelerometer that provided X, Y, and Z voltages having a stated Bias and Gain for each channel with an uncertainty of ±10%, and the thought of calibrating their device to determine the true Bias and Gain for each channel never crossed their mind ...].
Now that you have your Accelerometer calibrated so that you know, say, that ±1 V corresponds to ±1 g (9.8 m/sec²) (plug your actual calibration factor in here), you are ready to answer your own question. Do the following:
07-23-2020 06:49 AM - edited 07-23-2020 06:57 AM
Bobs coin method elaborated is the sine bar
If you find a mech-shop that has one and a set of gauge blocks you can do calibration 🙂
Math involves some matrix trigonometry ..
and if you look at your results closely, you migth find that the axis of your MEMS sensor are not perfectly all 90°...
(usually x,y are but the z-axis (not in the plane with the ligth/etching process) is a little off 🙂
(Do some more measurements and apply a linear fit)
I expect that the limit in resolution is found by looking at the drifts ... (and applying a low low pass filter 😄 )
(try a one day monitoring, and place it on a sunny (temperature.. sensor onboard ?) place.
Another good question: How to orientate the 3D accelerometer to get the best resolution?
