15v on protoboard reads 30v on multimeter - how do I correct this?
When i use the mydaq to read the voltage from the -15v, +15v ports on my protoboard, the reading is over 29v. If i measure the battery or 5v ports, the reading comes out correctly. Am I doing something wrong?
(2,341 Views)
You should read 30V if you measure between -15V and +15V 🙂
If you measure between AGND and +/- 15V you should read +/- 15V.
Greetings from Germany
Henrik
LV since v3.1
(2,215 Views)
