Measuring torque with myRIO
Background
I'm trying to measure torque with an torque cell (Transducer Technologies RTS-5) and myRIO. I've adopted NI's myDAQ/strain recommended code for the myRIO as suggested by NI here, but the output is garbage (noisy 0 V).
Sensor pinout
 torque cell pinouttorque cell pinout
Suggested connections
My connections
My code
 my codemy code
I'm a bit confused about the Wheatstone aspect of the torque cell. Does the transducer contain its own Wheatstone bridge, or do I need to make my own bridge and connect the torque cell as one leg of the bridge?
(4,455 Views)
The wiring seems correct to me. How are your tasks configured? In addition, have you tried this outside of a timed loop?
Brian.D
NI Product Owner
VeriStand
(4,397 Views)
Accepted by topic author aeroAggie
Hi Brian,
Sorry for the radio silence. I figured out my problem! The output of the torque sensor (a full bridge device) was at most 2 mV which is near the resolution of the myRIO's ADC. I used an op-amp to amplify the signal before reading it with the myRIO. However, I also realized that I don't need a myRIO for my application, so I've switched over to a USB-6361 DAQ + SC 2345 conditioning block + SG24 strain gauge modules which automatically excite and amplify the torque sensor.
(4,369 Views)
Hi Brian,
Is it will function the same if i using a NI 9215 module slotted to the NI cDAQ-9172(NI CompactDAQ) ?
(4,002 Views)
Hi Ashraf,
What are you trying to measure? I'm not sure an NI 9215 can handle bridge-based measurements.
(3,998 Views)
We trying to measure torque of a rotating wind turbine. Oh i see, that's mean I'm need a different module for bridge-based like NI-9237?
(3,995 Views)
Correct.
Some bridge-based sensors have a separate "box" that powers and scales the mV-level output of the sensor bridge into a standard analog signal (pos. and ground instead of pos. ground, and two ref. voltages). Then you can just use a standard analog input module.
Otherwise, you need a module made for bridge-based measurements.
(3,990 Views)
