03-10-2018 12:00 PM
I'm developing an autopilot on MyRIO board and I'm wondering if i could implement MAVLink mission compatibility to support GCS apps like QGroundControl, APM Planner, ...
Here is some info on MAVLink:
http://qgroundcontrol.org/mavlink/start
and another question
Is it possible to build MAVLink from its source files and convert them to DLL and Call it from RT and use it?
Thanks in advance,
03-12-2018 04:03 PM - last edited on 01-04-2024 05:44 PM by migration-bot
Moo127,
It looks like there has been some community work in a forum here (linked to a particularly helpful post on the thread) to work with MAVLink in LabVIEW. As far as compiling it into a DLL and calling it on the RT side--DLLs are Windows specific and you'd want to make sure to compile it to the right specifications for Linux RT, which is what runs on the myRIO. I've linked an article here on that. There's also a good white paper on integrating C code to Linux specifically. As far as integrating MAVLink specifically, I can't speak to the results you'll get, but it sounds like a really interesting project!
03-16-2018 05:22 AM
Thank you for sharing these resources
but the third on integrating C code to Linux didn't complete the tutorial on how to convert the static library to .os
it only demonstrated how to create a “Shared Library” project.
03-19-2018 04:57 PM - last edited on 01-04-2024 05:44 PM by migration-bot
Have you looked over the getting started guide for the development tools in Eclipse? That should take you through the steps to compile the source code into a .so, using the appropriate compile chain.
03-19-2018 05:56 PM
yes, I checked this tutorial and but don't know how to configure the project and covert the whole library to .so
03-20-2018 05:47 PM
So, right when you start setting up the project and get to step four of that guide, instead of creating an executable, one drop down below that will created a shared library. Setting the project initially to that and then using the Cross GCC compile should result in a .so file. Does that help clear things up?
