IMU BNO055 with myrio via i2c
 Hello guys,
I am trying to to communication adafruit board BNO055 with myrio, using i2c protocol. the sensor is not responding to the code.
can someone please help with the problem. the sample program is attached. it some reads the value from sensor but those values are garbage,while sensor is communicating perfectly with micrcontroller.
(5,199 Views)
Can you also post your subVIs? I'm guessing they contain the I2C code. I can say without looking at it that the first thing I'd recommend is to check the manual for the Adafruit board to make sure that you're addressing everything properly, as that's most often the issue in cases like this.
(5,165 Views)
Where you able to figure it out? I am having the same trouble.
(2,942 Views)
