12-02-2017 09:02 AM
I need to control a step motor, to realize motor's positive and negative going rotation, position controling, ect.
For control accuracy, I use myRIO FPGA to output levels that I want. After compiling FPGA, I start to run RT VI. It comes an error -61206. But I cannot find out the solution. Can u teach me?
Situations are as follows:
Solved! Go to Solution.
12-03-2017 06:57 AM - edited 12-03-2017 06:58 AM
first of all, u can see program execution by clicking lightbulb. After that You'll see when error occurs.
2nd i can't see depth configure. You should add controls to see and set actual depth for reading/writing. (if You're using it)
3rd You opened fpga reference, but after that u insert control to (open/write? myRio?) Can u show name of this control? Propably it's not necessary
Can You show FPGA VI?
Greetings
12-03-2017 07:59 PM
Hello Szyszku,
Thx for your advise. I have executed my program by highlight. It seems no errors.
Then, I followed your advise and deleted ''Open/Write myRIO''. There comes a new error.
Error code -61203.
Program that I amended, FPGA VI, and error code are below. Can u have a look for me?
It is very nice of U~
10-09-2018 06:34 AM
May i ask you to send me your program? I'm working on similar project, maybe i'll be able to help you.
Emil
