07-26-2017 07:12 PM
HI All,
In my PC Hokuyo already read and the VI its work but when I am using myRIO 1900, myrio cannot read Hokuyo URG-04LX-UG01. Do you have a solution?
07-27-2017 11:12 AM
How do you have your hardware connected? What is plugged into what?
Have you tried refreshing MAX or deleting and re-adding your myRIO?
07-28-2017 08:01 PM
I have already reastart myRio and refreshing MAX, it still same. Another solution?
07-31-2017 08:45 AM - edited 07-31-2017 08:48 AM
Found this great tutorial from Alex.T. You can see in the comments section that the URG-04LX draws a lot of current and you will need to power it separately from the myRIO.
Controlling a USB LiDAR using myRIO and the 'Classy' State Machine
https://forums.ni.com/t5/NI-myRIO/Controlling-a-USB-LiDAR-using-myRIO-and-the-Classy-State-Machine/t...
EDIT: Oh wait, that is a different device, you should be fine with your URG-04LX-UG01 LiDAR. Take a look at the tutorial, though. I see in the comments that someone using the same hardware as you was able to get it working by 1. Updating NI-VISA 2. Reinstalling software on myRIO.
08-01-2017 08:40 PM
How to reinstalling software in myrio?
08-02-2017 09:54 AM
Install Software on Your CompactRIO Controller
http://www.ni.com/getting-started/set-up-hardware/compactrio/controller-software
This tutorial says cRIO, but it should be almost identical on your myRIO.
