I am trying to install USB 6009OEM in Windows7, downloaded NI DAQmx 9.0.2 as given in the net as the device driver for windows 7, and installed the same. I am not able to find the device in the MAX. I went thru' some earlier discussion forum replies, and found that there are somw issues with regard to some MAX versions. I didn't find mine listed in that. The device exists in the control panel, though not under NI data acquisition boards. Please help..
There are two things to consider. The compatibility between the driver and LabVIEW and the driver and OS. You should be able to figure this out from the following KBs
