USB 6009
I am trying to install USB 6009OEM in Windows7, downloaded NI DAQmx 9.0.2 as given in  the net as the device driver for windows 7, and installed the same. I am not able to find the device in the MAX. I went thru' some earlier discussion forum replies, and found that there are somw issues with regard to some MAX versions. I didn't find mine listed in that. The device exists in the control panel, though not under NI data acquisition boards. Please help..
thanks
sree_spl
(6,270 Views)
Hallo,
It seems I have the same issue. Did you find a solution?
Best
Andrea
(4,910 Views)
Andrea,
There are two things to consider.  The compatibility between the driver and LabVIEW and the driver and OS.  You should be able to figure this out from the following KBs
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
http://digital.ni.com/public.nsf/allkb/90FD507D9CACE4A886257C6D00594EA2
If you are still not sure after that I would create a new post for your problem.  Some information to include in your post is
1. Operating System
2. LabVIEW Version
3. DAQmx Driver Version
4. Hardware
Then just restate the problem and it'll probably get answered quickly.
(4,895 Views)
