03-11-2014 07:24 AM
Hello Guys
I am using a NI myDAQ.
In my project I have to interface 4 MEMS pressure sensor whose output range is (0 to 1)V.
As there are only two AI channels in myDAQ (apart from DMM and Audio input). But I tried to use the stereo Audio input channels for acquiring data.
But it doesn't allow DC input and attenuates completely.
Is there any way I can use 4 channel input in myDAQ.
Any help is greatly appreciated...
Cheers,
Davidson D
03-11-2014 09:04 AM
Hey Davidson_D,
You should be able to read DC analog voltages using the Audio inputs. Another option is to build a simple analog multiplexing circuit to switch between the inputs (for example you couldu use the 74HC4051). You can control the mux using myDAQ digital outputs.
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
03-11-2014 11:50 AM
Thanks Sam.
I tried with Audio input by giving in a sine wave ranging from 1hz to 100 hz. I observed that only above 20Hz i get approximately actual amplitude i sent.
Below that the signal is not correct.
Is there any settings for audio input?
The switching idea is good one. I will try to implement that in my project. 🙂
Davidson D
