Hello, I'm really new to the myRIO, and I want to generate an ECG signal from an analog output of the myRIO using the NI biomedical toolkit to create the ECG signal. I also want to be able to see this signal from an analog input of the myRIO to check if its generating ok. My problem is that i don't really understand how to do this properly, i don't understand the correct data types for the analog I/O express VIs and how to properly view the input signal. I also have doubts about how the physical connections in the myRIO should be, for example. should I connect the output pin directly to the input pin? what about the ground?. I attached the myRIO project and just the Main.vi so you can understand clearly what I'm trying to do.
Any help its greatly appreciated. Thank you for reading.
