AR Drone Toolkit for LabVIEW - LVH
Problem with Pitch and roll in AR drone toolkit
Hello everybody,
Today I'm trying to fly with the AR drone in LV with the AR drone toolkit.
Vertical speed control, yaw control, hover control, emergency control, take off control, video streaming, navigation data are all working in my program.
But unfortunately there are problems with pitch and roll control. The drone gives no respons at all values I send.
I saw there were more people with the same problem, but I don't saw a solution.
My sequence in the program:
Init drone, connection
Loop:
Control drone (with watchdog functionality)
Read video data
Read navigation data.
If you know witch changes I need for the pitch/roll problem, please let me know!
Thank you!
Message 1 of 15
(14,724 Views)
I found the solution for this problem.
To fix this problem go to tools -> Options -> Front panel and disable Use localized decimal point.
Message 2 of 15
(13,235 Views)
Hi...
I Have The Same Problem...
I Have Tried Your Solution...
But...
Still Not Working...
So...
Message 3 of 15
(13,235 Views)
Ok, don't forget to restart LabView to solve this problem.
And be sure that you use the right values for max pitch and roll.
Message 4 of 15
(13,235 Views)
Done...
But Still Not Working...
Message 5 of 15
(13,235 Views)
ok, that's annoying.
Is it possible to control the vertical speed and yaw of the drone?
Be sure that you kick the watchdog at least 5 times per second.
Message 6 of 15
(13,235 Views)
Seems Like The Problem Was There...
I've Added The Tempo For Control The WatchDog And Suddenly...
It Works Now...
Thank You Guy...
I'm Very Gratefull...
You've Saved A Life
But The Animations Don't Respond Anymore...Even When I Add A Tempo...
Do You Have Any Idea Of What Wrong?
Message 7 of 15
(13,235 Views)
Hi guys, I used the same Toolkit but I had a the same problem of pitch and Roll control using joystick, could you please tell me how to kick the watchdog ?
m I supposed the make a delay in the watchdog subrutine ?
Thank you!
Message 8 of 15
(13,235 Views)
Another one with the same problem... If anyone knows how to solve it.. would do me a great favor...
Thank yoy very much.
<desperate emotion>
Message 9 of 15
(12,862 Views)
I have the same problem, I can change the vertical position anche the yaw angle but no the pitch and the roll. How can I change the WDT ? others solution?
Message 10 of 15
(11,417 Views)
