AR Drone Toolkit for LabVIEW - LVH
Connecting NI Vision with AR Drone 2.0 Video Feed
Hey Guys!
I'm working on an image processing project with the AR Drone 2.0 and we're using the LabVIEW AR Drone toolkit and NI Vision libraries for LabVIEW.  However, because the toolkit for version 2.0 of the AR Drone uses ffplay instead of LabVIEW to show the feed, we were unable to figure out how to extract the feed in order to manipulate it.
Any tips or starting point suggestions would be greatly appreciated.
Anish
Message 1 of 8
(19,911 Views)
Hi Asimhal,
   I have the same problem. If you have any idea we could try to develop it.
   I think that it's neccesary to develop one interface with the ffmpeg library but it's not a short time development.
    Jorge.
Message 2 of 8
(14,776 Views)
HI,
I have solved this by first take images with ffmpeg, and than read the images with labview.
However this isn't the right solution.
Maybe a preprocessing component in C can help.
I read the problem was tackeld in C and in ROS, but not yet in labview.
kind regards
Matthijs
Message 3 of 8
(14,776 Views)
Hi guys,
I have just posted a BETA version of the toolkit which incorporates native LabVIEW 2.0 streaming.  Check it out and hopefully it will be of some help.
AR Drone Toolkit with native video in LabVIEW for AR Drone 2.0 BETA
Justin D
http://www.ni.com/support/
Message 4 of 8
(14,776 Views)
Hey my friend did your method work?
Message 5 of 8
(14,776 Views)
My method and the method of JD_war_eagle both works,
There is some delay in the image, but I think that will always be the case when you are using ffmpeg. There is another difference in the standard toolkit and the adapted from JD_war_eagle and that is that the sequence number is included into the AR drone resource. But I think the program works great.
Message 6 of 8
(14,776 Views)
Yes i have tried JD_war_eagle's method and it works, I was having a problem with error 55 UDP write but i have solved that problem now. The image being returned by this method is an RGB image? How is it possible to pull this image into NI vision development module? Does the image type have to be converted?
Message 7 of 8
(14,776 Views)
Hi, i would like to know..is image processing possible for ar drone 2.0 using VAS?
because it seems that NI-IMAQDX devices under NI MAX cant seem to detect the camera.
If so, what else can I do for image processing for ar drone 2.0 video stream?
Message 8 of 8
(14,776 Views)
