There is a delay of the video stream. This is mainly caused by the wifi connection (which is not one of the fastest connections...). Also LabVIEW has to process the video, which also caused some delays.
This is less than 0.5 seconds but can be annoying if you are following an object. I recommend you to use some kind of position prediction if you need to. This might compensate the delay.
