08-07-2016 09:35 PM
08-09-2016 09:34 AM
Hey Becky, I finally got a chance to watch your presentation (thanks mballa for recording). It was great! Here are a few points I would have made if I was there when it happened:
08-09-2016 10:56 AM
08-09-2016 11:24 AM
Sure thing, glad to help!
09-26-2016 04:43 PM
In your presentation we talked about dropping a VIT from the palette and we discovered that if you did that, you dropped the actual template, and not a new copy of it. I suggested making an XNode, but forgot about it until today when I actually needed it. So I posted my XNode over on LAVA.
https://lavag.org/topic/19829-drop-vi-template-xnode/
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-19-2018 02:17 AM
Hi JLMommy!
Your presentation is very helpful to me to create project template using VIPM.
I am trying to create my project template using VIPM my source folder is created but mete data file not generated. While creating project template we specify the Base path and subdirectory for source. Where we can specify the metadata file path?
09-19-2018 02:22 AM
Hi JL Mommy!,
Your presentation is very useful to me to create project template in VIPM.
I am Trying to create my project template using VIPM But I have one problem.
We specify the base path and subdirectory path for source. My source folder is crated but meta data file not generated. Where we can specify path for generated metadata file?
