[IDLE] தமிழினி
XML format data
Hi team ,
I am writing the array data  content as xml file .
In the XML file , test parameters name also ( Caption )   i need to Write  .
I gave as 1d array as output  , so all caption / Parameters are all listed as " Status " .
But  parameter name  i need to write first ,  after that  i need to write the parameter value in the file
For eg :
Parameter name  : Testcase name
Parameter value  : Voltage Test
Parameter Name : Higher limit Value
Parameter  value  :  5
Attached the screenshot of xml file and Test vi .
Please advise and suggest
Thanks in advance
(1,824 Views)
Hi @Mrtechie ,
Please check this Toolkit by JKI.
It can provide you with a better XML format of the LabVIEW data.
LV Data -> XML Data : BDLV Data -> XML Data : BD
LV Data -> XML Data : FPLV Data -> XML Data : FP
JKI Easy XMLJKI Easy XML
(1,794 Views)
