kl3m3n's blog
Community Browser
Re: Point cloud registration tool
Klemen
I am attaching an application (with graphical user interface - GUI) that can be used to register/align a pair of point clouds. Filtering can also be performed prior to the registration process. The application is partially inspired by Geomagic's cloud registration functionality (although my interface is not nearly as fancy ). There are three registration possibilities:
  1. Manual registration, based on manually selecting the corresponding points on two point clouds (using PCL),
  2. Sample consensus initial alignment, based on descriptors that are extracted from the two point clouds (using PCL),
  3. ICP registration, which produces very similar results as the Geomagic's global registration - at least on the datasets I've tested (using trimesh2). The algorithm is fast and more information can be found in the paper "Efficient Variants of the ICP Algorithm" by Rusinkiewicz S and Levoy M. I used the trimesh2 library because I wasn't getting good results with the PCL's ICP algorithm (using the classical ICP from PCL 1.6.0). I have not tried to create my own ICP pipeline as suggested on the PCL forums. Possibly this would provide much better results.
Figure 1 shows the main user interface with two triangulated point clouds that need to be registered.
Figure 1. Main window of the application.
Clouds from Figure 1 cannot be aligned with ICP directly, so some preprocessing is necessary. Figure 2 shows the user interface for manual registration. The transformed cloud based on the manual registration and target  cloud are shown at the bottom of the interface.
Figure 2. Interface for manual registration.
By selecting "OK", the transformation values are passed to the main window and the transformation matrix indicator is updated accordingly (see Figure 3).
Figure 3. Manual registration.
Performing the ICP improves the result by minimizing the errors and the transformation matrix indicator gets updated (see Figure 4). Multiple ICP routines can be executed by clicking on the ICP button.
Figure 4. ICP registration.
In every step, the clouds can be visualized in main window as points (see Figure 5) or surfaces (see Figures 1,3,4).
Figure 5. Data from figure 4 visualized as points.
Additional information on the controls and indicators can be found by clicking on the Help->Instructions on the top-left corner of the GUI (see Figure 6).
The requirements to run the application are PCL 1.6.0 and Qt 4.8.0, where you need to add the "bin" paths to the PATH system variables.
The application is at this time provided as .exe only and can be found in the attached .zip file. The .zip file is password protected in order to potentially avoid the virus scanning during upload. The password is in the attached .txt file.
There are possibly some bugs - if you test the application and have the time, please provide feedback.One of the bugs is related to the manual registration only after re-opening the manual registration window. The picked points are not always displayed on the cloud, although they are registered (see the cmd output window).
P.S.: The input cloud(s) must be in the .pcd format. Example (column 1 - X data, column 2 - Y data, column 3 - Z data):
# .PCD v0.7 - Point Cloud Data file format
VERSION 0.7
FIELDS x y z
SIZE 4 4 4
TYPE F F F
COUNT 1 1 1
WIDTH 3171
HEIGHT 1
VIEWPOINT 0 0 0 1 0 0 0
POINTS 3171
DATA ascii
10.000000    25.000000    -5.000000
11.000000    26.000000    -4.000000
14.000000    29.000000    -1.000000
-112.290000    164.349000    82.436000
-111.669000    159.135000    85.179000
-110.629000    154.515000    91.104000
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Comments
Tan3D
Nice work !!
Can you provide the source code of tool ? I am intersested to know how you selected manually corresponding points. Also i want to know how to run the tool on ubuntu
Thanks in Advance !!
geucimar
Thank you!
Could you share the code please?
张斌
3D Vision Advanced Toolkit For LabVIEW
http://sine.ni.com/nips/cds/view/p/lang/zhs/nid/217368
The toolkit mainly includes a 3D point cloud processing library, a triangle mesh processing library, a 3D picture interactive library, and a height field data processing library.
1)3D point cloud processing library
The 3D point cloud processing library includes point cloud simplification, point cloud smoothing, point cloud clustering analysis, point cloud rendering and storage.
2)triangle mesh processing library
The triangular mesh processing library includes point cloud triangular mesh reconstruction (3 methods), mesh hole analysis and filling, mesh smoothing, mesh section calculation, area volume calculation, 3D mesh rendering and storage.
3)3D picture interactive library
The 3D picture interactive library mainly provides methods for selecting the point cloud and 3D grid in the 3D picture control by frame selection and polygon selection.
4)height field data processing library
The height field data processing library includes functions such as height field data smoothing, height field data triangular mesh reconstruction, four-corner mesh reconstruction, rendering and storage.
Email: Technology@cos-3d.com
