kl3m3n's blog
Community Browser
Re: Create a range image in LabView from 3D point cloud using PCL Z-buffering
Klemen
it is often of great value to compare the difference in depth of two objects after the 3D alignment of two point clouds. Obviously, this cannot be performed directly on the acquired depth images, since after the alignment (ICP for example) the indices from one depth image do not neccessarily correspond to the other depth image. Thus the depth calculation difference is erroneous.
This can be performed correctly using Z-buffering. I use a 3D viewer (developed at my company) that is able to obtain depth images from the specified viewpoint in the viewer. This makes it possible for me to correctly determine the deviation between two surfaces after the ICP alignment. Sadly, I cannot share the above mentioned viewer code, so I have prepared an alternative using the functionalities of the Point Cloud Library. The core of the code is basically taken from here:
http://pointclouds.org/documentation/tutorials/range_image_creation.php
and
http://pointclouds.org/documentation/tutorials/range_image_visualization.php
The screenshots below show the example. The code creates a pose of the virtual sensor using a specified coordinate system and creates a range image from a 3D point cloud(for more information, check the text in the first link above). I suggest using such setup that the axes of the measured object are aligned (as much as possible) to the axes of the coordinate system.
Figure 1. 3D of the measured surface.
Figure 2. Depth image (Z-coordinate) from Figure 1 (top) and the range image taken form the 3D point cloud from Figure 1 (bottom).
Please don't ask why the depth scale is different for both cases and it really should not matter, when comparing two range images taken with the same setup parameters, since only the difference is relevant.
The code I am attaching is the source code (c++), built .dll (release version) and a LabView example that uses the .dll.
The code was built using PCL 1.6.0 and the LabView version is 2010.
Like always, please leave any comments below!
Hope this helps somebody.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Comments
VandanaR
Hi Klemen,
I m using Windows 10 64-bit with PCL 1.7.2 and OpenCV 2.4.9 installed. I have also install the Labview PCLOpenCV Toolkit from JKI. When I open the VI, it throws an error saying "Library not found or failed to load." I did re-link the dll to the path where it exists. It still throws up the same error.  I had the same issue while using any of the VIs from Labview PCLOpenCV Toolkit. I have a similar requirement to convert a 3D point cloud data to 2D range image. It would it be helpful if you would help find a solution or if I'm missing out some installation files. Error-Call Library not found or failed to load
