11-15-2012 10:16 PM
Hi, I would like to know the switching time between the analog input channels for WSN 3202.
Since it is a multisample device, i want to know the amount of time delay between those channels so i can manipulate the delay to simultaneously sample the channels.
11-16-2012 02:51 PM - edited 11-16-2012 02:52 PM
Hi nurlaila,
The 3202 uses a multiplexer for the analog inputs so it cannot perform true simultaneous sampling but it can do near simultaneous samples. What are you trying to sample and how fast of a settling time do you need? There is not a direct way to change the settling time as with DAQmx devices. However it can be indirectly effected by the settings you chose for the device.
Cheers,
Brian A
R & D Product Support Engineer | WSN/Network DAQ/Academic
12-20-2012 03:59 AM
Hi Brian,
I understand that the switching time between the channels is too small, but is it measureable? I just want to know the time delay.
Thanks.
