Wireless Sensor Networks
is it possible to connect thermocouple with NI WSN 3202, 3231 and 3232 Nodes
I want to get temperature readnigs using 3202, 3212, 3231 and 3232 nodes. as per specifications 3212 is having input lines for thermocouple. is it possible to get thermocouple readings using 3202, 3231, and 3232 nodes using analog or digital input lines.
(5,407 Views)
you can use other nodes mentioned above also , but needs to be checked whether it allows differential input or not. also you can use 3202 node and make logic in LabVIEW to convert voltage reading into the degree celcius.
try this out
thanksSmiley Happy
(5,403 Views)
thanks abh for valuable reply.
(5,400 Views)
