You can't change the properties of the channel because it is essentially a system channel, not a user channel. It is linked to a physical line.
It looks like you are using a 3202?
How long did you wait for the digital line to toggle? Depending on the update rate you set for the node (right-click node, properties), it could take several seconds.
Chris
Certified LabVIEW Developer
