NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
hugosantos
ZigBee
Hi engineers, I'm used the hardware WSN 9791 and WSN 3202. Exist someone hardware which amplify the signal ZigBee? Some kind of router.
Regards
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Active Participant
DavidS.
Re : ZigBee
Hi Hugo,
Each WSN node could be configured as router so if you want to increase the distance between your gateway and your end node, put another node configured as router between its.
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
Journées Techniques LabVIEW 2012 : du 27 septembre au 22 novembre
2 sessions en parallèle : Débuter a...
Member
hugosantos
Re: ZigBee
Good afternoon, I wonder if there is compatibility of your products, with National Instruments, including NIWSN9791, NIWSN3202. I need to amplify the signal ZigBee. I would appreciate an answer soon.
Regards
Hugo Santos
Member abh
Member
abh
Re : ZigBee
can transferring audio file is possible using wsn 9792(ethernet gateway) and 3202 nodes? how please help.
Active Participant
DavidS.
Re : ZigBee
Hi abh,
If you want an answer quickly, post in a new topic.
Sincerely
Member abh
Member
abh
Re : ZigBee
okay..
Member abh
Member
abh
Re : ZigBee
sir, i am new to discussion forums so i won,t be able to post it new topic please guide
Member abh
Member
abh
Re : ZigBee
sir,
please tell me how to transfer the audio file using wsn 9792 and wsn nodes
Active Participant
DavidS.
Re : ZigBee
You could click here and create a new message (on the top, you have "New Topic")
http://forums.ni.com/t5/Wireless-Sensor-Networks/bd-p/430
Sincerely
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
