NI Home
Cart Cart | Help
You are here:
Reply
Member
hugosantos
Accepted Solution
WSN status code
Good morning Engineers,
I try implement a program, where apeear the status this node, in other words, I want visualize if this node is connect or not.
Until now still can not build code that did this. I do not have the WSN Module Pioneer installed, this module need to create this code.
Regards.
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Active Participant
Romain_Duval
Re : WSN status code
Hello Hugo,
here is a way to do it: KB
Romain DUVAL Certified LabVIEW Developer/ Certified TestStand Developer
National Instruments France
TÉLÉCHARGEZ dès maintenant TOUTES LES PRÉSENTATIONS TECHNIQUES !
Merci aux 1155 visiteurs qui sont v...
Active Participant
Romain_Duval
Hi Hugo,
Another document which might be interesting:
WSN API
regards
Member
hugosantos
Hello Romain,
Thanks for your reply. This way is correctly.
Hugo Santos
Member
hugosantos
Good morning, thanks for your reply.
When I turn off the Gateway to the pc 9791 WSN, the WSN node 3202 is still connected to the gateway, how do I break this link?
Hugo Santos
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
