Wireless Sensor Networks
WSN Node List Disabled in NI-MAX
After installing the WSN 1.2.1 firmware on two of my NI-9792s, the node list in NI-MAX is now disabled. I can see the list, but everything is greyed out. When I access the nodes through the built-in web server they are editable, but I am really needing to edit the list through NI-MAX as well. Why are they greyed out, and how can I begin to edit the list again?
Thanks!
Garrett
(7,000 Views)
I have the same problem too.
My configuration is as follows:
- Windows7 Pro
- MAX version 14.0.0f0
- NI9792; firmware revision 2.1.2
- NI9792; operating system NI Real-Time VxWorks-PPC603 6.3
The configuration of the WSN nodes is still available through my browser because I installed the "NI web based configuration and monitoring 14.0.0" software in the gateway.
Any advice?
Bye
Flavio
(4,598 Views)
Hi Flavio05,
It looks like you're responding to a thread that's about 5 years old. I would recommend making a new thread instead, as it means that your question will get more visibility and is more likely to be answered in a timely manner.
Kathryn K.
Technical Support Engineer
http://ni.com/support
(4,588 Views)
