Wireless Sensor Networks
Using outputs in WSN-3202
Is it possible to show me an example for an output of 12 v? For example for connecting a LED 6v.
Regards
Hugo
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Message 11 of 18
(3,063 Views)
The screenshot of program you've sent with your second post is already good. When DIO0 turns to true, the physical output is set to 12V.
For lighting a 6V LED, you'll have to use a voltage divider.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
Message 12 of 18
(3,058 Views)
Thanks for your help!
Finally, WSN node to join the other 3202, I can get 24v?
By the way, for another topic, I want to connect multiple vi's, where I can find info on this?
Hugo
Hugo Santos
Message 13 of 18
(3,054 Views)
I'm sorry but I don't understand your question.
For your second question, can you create an other topic ? It's easyer for people to find informations if any topic is used for one question
Message 14 of 18
(3,041 Views)
Good morning,
I want an output voltage of 24v. How can I convert 12v to 24v?
Are there any amplifier on the market?
Hugo
Hugo Santos
Message 15 of 18
(3,032 Views)
Good morning, I tried to get a value of output. But is not read any value.
Can you help me?
Greetings.
Hugo Santos
Hugo Santos
Message 16 of 18
(3,022 Views)
Good morning, I implemented the code, which will annexed. I can not get any value.As the wires are connected in the output ports?
Greetings.
Hugo Santos
Hugo Santos
Message 17 of 18
(3,016 Views)
Hello hugosantos,
Please create a new topic for your question.
Message 18 of 18
(3,008 Views)
