03-09-2012 09:21 AM - edited 03-09-2012 09:30 AM
Is it possible to show me an example for an output of 12 v? For example for connecting a LED 6v.
Hugo
03-09-2012 09:40 AM
The screenshot of program you've sent with your second post is already good. When DIO0 turns to true, the physical output is set to 12V.
For lighting a 6V LED, you'll have to use a voltage divider.
Mathieu P. | Certified LabVIEW Associate Developer
National Instruments France
03-09-2012 09:49 AM
Thanks for your help!
Finally, WSN node to join the other 3202, I can get 24v?
By the way, for another topic, I want to connect multiple vi's, where I can find info on this?
Hugo
03-12-2012 03:22 AM
I'm sorry but I don't understand your question.
For your second question, can you create an other topic ? It's easyer for people to find informations if any topic is used for one question
03-19-2012 07:09 AM
Good morning,
I want an output voltage of 24v. How can I convert 12v to 24v?
Are there any amplifier on the market?
Hugo
04-09-2012 05:49 AM
Good morning, I tried to get a value of output. But is not read any value.
Can you help me?
Greetings.
Hugo Santos
04-18-2012 04:40 AM
Good morning, I implemented the code, which will annexed. I can not get any value.As the wires are connected in the output ports?
Greetings.
Hugo Santos
04-20-2012 04:42 AM
Hello hugosantos,
Please create a new topic for your question.
